SailNet Community - View Single Post - Shaft Coupling Stuck to Transmission Flange
post #7 of Old 09-03-2015
overbored
overbored's Avatar
Re: Shaft Coupling Stuck to Transmission Flange
that is a federal flex coupling it has set screws that hold the shaft to the inner part and the big nuts hold the inner hub in the outer ring. there should be flange on the trans that bolts to the outer ring.
Marine Transmissions, Velvet Drive, Paragon, marine transmission parts,
"GOLD RUSH" PRINDLE 16
overbored is offline
The Following User Says Thank You to overbored For This Useful Post:
brownoarsman (09-03-2015)
