SailNet Community - View Single Post - Water System Op
Thread: Water System Op
post #11 of Old 09-15-2015
CraigLisk
The handle for the faucet on the CS27 lifts up and acts as a hand pump if the electric pump is not turned into. The faucet it self has an electric switch attached to it, a push button switch that opens when you lift or open the faucet. When the switch is on the electric pump will start. However, the switch can stick and if it does it will not turn the pump on. The switch works the opposite of most push button switches of this type so it may be difficult to find a replacement if it goes. You can take apart the faucet by removing some pins in the handle to get at the switch. Replacement faucets of the same designs are still available online.
Craig Lisk
Former CS27 owner 1158
CraigLisk is offline
