SailNet Community - View Single Post - Low buck projects- Let's see 'em!
post #1436 of Old 09-23-2015
Barquito
Barquito
Barquito's Avatar
Re: Low buck projects- Let's see 'em!
Cheap storage for those small propane bottles that you don't know how to store. I went to Home Depot and bought a three-foot piece of #10 PVC pipe the right diameter to hold the bottles, a glue on (I know it's called weld) bottom cap and an adapter and screw on top. Put it all together, drilled several holes in the bottom and attached the rig to one of the slanted legs of the stern pulpit with a couple of hose clamps. It's lasted for about 10-years now and shows no sign of wear.
I have the same setup. Most stern pulpits are not vertical, so make sure you have holes in the bottom of the pipe that are near the edge, not in the middle.
Valiant 32
Barquito is online now
