SailNet Community - View Single Post - TS Joaquin
Thread: TS Joaquin
post #36 of Old 10-01-2015
CapnRon47
Re: TS Joaquin
Catherine,
I am in Oriental. If you come thru Oriental (before taking the Minnesott Ferry) you might check the Marine Consignment store for used anchors, chain and rode, they usually have a supply. I stripped my sails and all canvas (Sunbrella) today. Plan to anchor up a creek tomorrow, just in case. I have only been thru Irene, she stalled and the water came in slowly, but went out in a hurry. So make sure you have anchors set to hold for rising water and outgoing water. I tie off to trees, in addition to anchoring (just because there are plenty of them). There are lots of places on both sides of the Neuse to hole up. What you want to do is shelter your boat from open water (long fetch). If you can find a spot around a corner then you will just see water rise and fall and not much in waves. The wind here is usually not too bad, but depends. Removing canvas is a good idea.
Good luck,
CapnRon47 is offline
