SailNet Community - View Single Post - epoxy resin vs. polyester resin for hole repair
post #4 of Old 05-08-2008
artbyjody
artbyjody's Avatar
Use Epoxy unless you are absolutely positive that your decks are made from poly / vinyl. Epoxy is the only one that can bind to any of the the construction / lay-up methods used.
Be wary tho - mix only small batches - and have your areas prepped and ready to go before you start mixing and patching....I use regular painters tape around areas or parchment(wax paper) paper to isolate areas..(such as holes underneath)...
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
