SailNet Community - View Single Post - Atomic 4
Thread: Atomic 4
post #7 of Old 11-04-2015
RichH
RichH's Avatar
Re: Atomic 4
The block and exhaust manifold of the A4 are cast iron.
When continually and repetitively heated above 150F the internal 'rust' will become a blue/black form of rust (ferrous oxide) which is 'protective'. With long periods of lay-up, this ferrous rust will convert back to destructive red (ferric) rust.
Rx to keep the rust 'black':
1. run hell of the engine, keep the water temp at a bit over 150 (regularly check that raw water thermostat for proper operating temperature).
2. Never, never, never, ever drain the water from the engine for long term 'lay-up'; always fill up the cooling system with 50:50 antifreeze mixture with added 'anti-rust' compounds. The oxygen laden moisture remaining in a 'drained' cast iron engine will greatly accelerate the 'black' rust rapidly converting into destructive 'red' rust.
3. Never, never, never, ever 'pickle' such an engine or exhaust manifold with muriatic or hydrochloric acid (or 'vinegar', etc.) to remove the usual internal calcium carbonate scale buildup/fouling. ONLY 'descale' the engine with an INHIBITED descaling chemical such as RydLyme, etc. Then run the hell out of it to restore that protective ferrous black rust.
4. Convert the engine to 'fresh water cooling' (heat exchanger).
Good source of info for maintenance, repair, rebuilding, parts, 'modernizing', etc.: Moyer Marine Atomic 4 Engine Rebuilding and Parts
RichH is online now
The Following User Says Thank You to RichH For This Useful Post:
scubadoo (11-05-2015)
