SailNet Community - View Single Post - Sailboat without a mast
post #85 of Old 01-07-2016
centerline
centerline's Avatar
Re: Sailboat without a mast
Originally Posted by Wesman100 View Post
I know this is an old thread but thought I would reply anyway.
I had thought of something like this and have read a few articles where some folks have actually done it. I recently bought a Mac 22 and with this boat there is no need to make any changes. It's small enough to add a mast stepping system and with the swing keel I can raise/lower the keel to suit my needs. Raise the mast for stability while motoring or sailing, or leave it stored across the cabin. If you plan on extensive cruising the 22' would be a bit (well, more than a bit) small. Which makes me wonder, what would be the maximum size sailboat that a mast stepping system would be practical?
as the owner of many different boats throughout my life, I can shed some reasonable light on this.
its really not a worry for those that want to remove the mast from a sailboat and use the hull as a cruiser only... there definitley are pros and cons, but for the most part, thru this entire thread it has been about how rolly the sailboat would be in a seaway without the mast, and, yes it is a fact.... but not so much that it is unbearable like so many "swear" it is.
these people have obviously never been aboard a powerboat in a choppy seaway....
my point is, they are comparing a sailboat without a mast to a sailboat WITH a mast, so yes, they are correct. but when comparing the mastless sailboat to a powerboat, the sailboat is more stable.... a 30' powerboat bobs like a cork, but can sink like a rock when inverted... at least the mastless sailboat will return upright.
as for trawlers, they CAN ride better because some of them DO have a shallow, but weighted keel... and all of them are designed to be as stable as possible, but for a man on a budget as most who would consider doing this is, a trawler is out of the budget.
and it IS true that a sailboat is quite a bit more fuel efficient than an equivalent powerboat.... and boats in the 28 to 32ft range, all have about the same storage space available... when they start getting bigger, the powerboats do begin to have larger spaces to store stuff.
for those that think one could by an old powerboat and put a smaller engine in it to gain the fuel economy... this is not very well thought out statement.
powerboat hulls do NOT slip thru the water as easily as a sailing hull does... and by the time one gets done repowering/modifying the powerboat hull in an attempt to make it as fuel efficient as the sail hull, the sail hull will can be thousands of miles away, with money still in the kitty.....
I am also a firm believer that all things being equal between a smaller "budget" sailboat and the traditional style "budget" powerboat, a sailboat is a more comfortable home for long term cruising....
And, if I was out somewhere in the ocean broke down, where help may be days or weeks away, I would much rather be in a mastless sailboat, than I would in a traditional powerboat... because during a storm, it is safer even if you only take a minimal amount of care.
trawlers are not included in this assessment because I believe that anyone considering doing this is working on a tight budget...
even if it does go against the grain of what most people want to believe, it can be a very economical way to go boating... but one should consider the reasonable pros and cons, not the unreasonable ones....
Cal 34-III, Nu Liberte
Portland, Oregon
it seems as if there is a growing population of people in the world, who dont have sense enough to recognize a senseless idea when it enters their mind...
When you are dead, you dont know you are dead so it doesnt bother you, but it can be really difficult for others...
its the same when you are stupid....
centerline is offline
