SailNet Community - View Single Post - Secondary anchor retrieval
post #3 of Old 08-02-2008
johnshasteen
johnshasteen's Avatar
Paloma being on 30', I only use the windlass if I'm in really deep water and have a lot of chain out - I try not to do that. In shallow water - which is much more common down on the Gulf Coast, I don't use the windlass at all. I set both anchors out by motoring up, dropping the first anchor, then backing up to set it with about an 8-1 scope (I only use 12 feet of chain), forward again at an angle and drop the second - same drill. To retrieve them, I motor up slowly to overrun and pull out the closest anchor, leave it dangling off the anchor roller, then same drill for the second one. Once both anchors are freed, I turn back to the channel, one at at time pull them to the side and lower them to just below the water line to wash them off. Be careful not to let them bang into the hull - ask me how I know???
s/v Paloma, Bristol 29.9, #141
Slipped in Bahia Marina, easy access to Corpus Christi Bay and the Gulf of Mexico.
johnshasteen is offline
