SailNet Community - View Single Post - Swinging while at anchor
post #2 of Old 04-11-2001
paulk
paulk's Avatar
If it works, do it. Yawing at anchor could be caused by a lot of things - wind, current, each singly or both together. We''ve found sometimes simply tieing the rudder over a few degrees to one side or the other will stop it. Otherwise, hoisting a small steadying sail on the back end of the boom or off the backstay may work. For a Cal 27, the jib from a 420 or other similar-sized boat might be big enough. It should be easy to borrow one to see. A piece of canvas might also do the trick. DON''T use a piece of blue poly tarp - we''d prefer you suffer with the yawing than subject the rest of us to a sight like that.
paulk is online now
