SailNet Community - View Single Post - Install water heater
post #2 of Old 06-12-2016
JimsCAL
JimsCAL's Avatar
Re: Install water heater
A couple of thoughts. How is the heater connected? Series or parallel? If parallel, then all the water does not go through the heater. Look for "tees" to determine your hookup. Even if series and all the water does go through the heater, you should be fine. My Yanmar 3GM30F which has similar power to your M25 has all 5/8 inch hoses. Don't forget hose size is based on ID not OD.
JimsCAL is offline
The Following User Says Thank You to JimsCAL For This Useful Post:
davidpm (06-12-2016)
