SailNet Community - View Single Post - Windlass technique: use messenger/snubber line with chain?
post #7 of Old 08-08-2016 Thread Starter
TakeFive
TakeFive's Avatar
Re: Windlass technique: use messenger/snubber line with chain?
Originally Posted by eherlihy View Post
I suggest using a trip line to get the MansRocMant up. It will come up cleaner, easier, and this line will allow you to keep the chain where it belongs; as a leader to your anchor.
I had used this setup, until the float that I used failed, and then the trip line chafed through. I didn't loose the anchor though!
That's exactly what I had in mind. The float is a nice touch because it keeps the line out of the mud. Then I could wrap the trip line around the windlass drum if I need mechanical assist for hauling in the chain.
Any other negatives to this arrangement?
Also a question about your 5/8" shackle. Is that a free-rotating shackle? My anchor currently has one, and my surveyor told me to remove it because it is a common point of failure. Is twisting a problem if you don't have it?
Rick S., Swarthmore, PA
USCG Certified Captain, OUPV and 50 Ton Master
2001 Catalina 34MkII Tall Rig Wing Keel Breakin' Away, Universal Diesel M35B, Mantus 35 lb. anchor, sailing out of Rock Hall Landing Marina
TakeFive is offline
