SailNet Community - View Single Post - Battery recommendation for Crealock 34
post #3 of Old 09-05-2016
stipakb
stipakb's Avatar
Re: Battery recommendation for Crealock 34
I use 3 Lifeline GPL-31XT AGM batteries, for a total of 375 amp hour capacity (125ah x 3).
This photo shows how all 3 batteries fit in the original PS34 box:
To get the outboard, forward battery (right, top, as you look at the photo) to fit right, I built a custom plywood platform for that battery that raises that battery slightly. The battery still clears the 3/4" plywood cover that I built that goes over the top and is secured with heavy bolts at the outboard end and slides under a wood strip at the inboard end (I can take a photo of the cover if you want to see that too).
Brian Stipak
Portland, Oregon
stipakb is offline
The Following User Says Thank You to stipakb For This Useful Post:
cshrimpt (09-05-2016)
