SailNet Community - View Single Post - Battery recommendation for Crealock 34
post #5 of Old 09-05-2016 Thread Starter
cshrimpt
Cruisin' for a Bruisin'
Re: Battery recommendation for Crealock 34
If you had an additional 1" - 1.5" of height you could even fit two Lifeline 6V L-16's which would also yield 400Ah.
The Lifeline is only an inch taller than the Rolls so they would work. I've been shying away from AGM batteries after I read an interesting article that claimed that AGM batteries charge no faster than a lead acid battery unless you have the amps to drive it.
Apparently since the acceptance rate is so high with AGM, you really need a 200 + amp alternator to really take advantage of the charge speed. Otherwise you're wasting your money on high-end batteries you really can't take advantage of.
Shrimp
S/V Wayfinder - 1985 Pacific Seacraft 34
cshrimpt is offline
