SailNet Community - View Single Post - Should I only use the house bank at dock?
post #5 of Old 10-06-2016
Stu Jackson
Stu Jackson's Avatar
Re: Should I only use the house bank at dock?
Originally Posted by cshrimpt View Post
My I/C is an ancient Freedom 10. It just has the single output cable which is why it is connected to the battery switch. I'm probably due for an upgrade.
Thanks,
Shrimp
WADR, nonsense. I have an "ancient" Freedom 15 that I installed in 1998. There is no way in hell I'd tie it into the 1-2-B switch. That is NOT what the instructions say to do. You need BIG 2/0 cables from the I/C to the house bank. Period. Nowhere near the switch. You are very lucky you haven't had problems. Big problems.
You don't need an upgrade, you simply need to wire it properly.
The manuals are still available on Xantrex's website under discontinued products.
I installed a Yandina combiner, too.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
