SailNet Community - View Single Post - chainplate fabrication..
post #3 of Old 09-16-2008
catamount
catamount's Avatar
Some rigging shops do have metal fabrication capabilities, and while you could go to a generalist metal shop, the rigger will likely have a better sense of the requirements for the finished piece. I have used Chesapeake Rigging in Annapolis to fabricate new chainplates and and a new stem fitting for my boat. I have been generally impressed with their work.
I used a local welder to make up some new special bases for my stern pulpit that double as the mounting points for some turning blocks; while the latter pieces are OK, the finish was not polished at all, and I suspect there may be some weak spots that could be prone to crevice corrosion in the future...
Peterson 34 GREYHAWK, West Boothbay Harbor, Maine
, a new voice for ocean conservation
catamount is offline
