SailNet Community - View Single Post - New owner of a Parker Dawson 26 Ketch
post #19 of Old 10-20-2016
cw3hogan
Chief
cw3hogan's Avatar
Re: New owner of a Parker Dawson 26 Ketch
Allen, thanks for the detailed reply! I can't do PM's yet. Too few posts. Anyway, Wow, a lot of work on the Midship! She's beautiful. So is the PD 26. I lucked out when I found out my colleague's dad was trying to give away a sailboat. No one seemed to be interested! The Midship had been stored in a large shed for several years. The boat is in great shape, very clean and mostly dry. As I said before there is no engine and the aft marine head was missing too. I'm doing a detailed survey chasing wires, scuppers, water lines, hull, etc. Currently the boat has been fitted with an outboard motor mount on the transom. It is an awkward set up for handling with the aft cabin in the way. So I'm going for a sail drive setup as best choice. 2nd choice would be installing a prop shaft through the hull with all the associated hassles like shaft alignment, thrust bearings, etc. I have some experience working on and handling motor vessels as a deckhand. Anyway, any suggestions where I could find similar drive systems for the Midship? This is a new area for me. I intend to sail most of the time. The motor is mainly for safe navigation in and out of marinas. To motor sail or just motor seems I would need a bit more horsepower e.g. 15+ HP. The fuel tank is 15 gallons I believe.
On a side note I noted in the forward cabin under the cushions near the bow is a stowage area filled with foam! Not sure why. I suspect the designer did not want any excessive weight stowed near the bow to prevent the bow plowing into waves. Just a guess.
Thanks!!
Shannon
cw3hogan is offline
