SailNet Community - View Single Post - Sad looking zinc's
post #16 of Old 11-12-2016
Fstbttms
I don't discuss my member
Fstbttms's Avatar
Re: 'Sad Zinc's' might lead to other Sadness
Originally Posted by svHyLyte View Post
As the zinc's erode, the irregular wasting creates an imbalance of the weight distribution about the longitudinal axis of the shaft. As the shaft rotates, the imbalance causes the shaft to "whip" or wobble which leads to rapid deterioration of the cutlass bearing and your packing gland packing material.
Give me a break.
Originally Posted by boatpoker View Post
I'd suggest against the use of aluminum anodes in salt water as they... will disappear even faster than zinc.
That is simply untrue.
Originally Posted by olson34 View Post
Looks like your marina has some serious stray current going on.
Considering that the OP's other boat did not suffer excessive anode depletion, I'd say the best bet is that the issue lies aboard the boat in question, not with some general, marina-wide problem.
Fstbttms is online now
