SailNet Community - View Single Post - Mirage 27 (Perry design) - rudder repair
post #7 of Old 12-15-2016
Koinonia M27 323
Re: Mirage 27 (Perry design) - rudder repair
am in process of doing that this winter. Mine is wheel steering, does not have a emerg tiller connection. To drop rudder, disconnect quadrant, place support under rudder before unbolting rudder post at top near transom. Then unbolt at transom then drop rudder after removing supports. May have to dig hole under rudder to get it out if too short to the ground. Then i would dry for a couple of weeks, then drill and fill, then glass several layers over crack, see youtube videos. Small layer first, make wider layers, extend to about 4" down either side to reinforce, let dry and sand and paint. Good to go for next summer.
I want to be a sailor when i grow up, my wife says i can't do both.
Koinonia M27 323 is offline
