SailNet Community - View Single Post - CAL 25 - Tweaked Boom, Chainplate Leak - Advice welcome
post #8 of Old 03-16-2017
Jeff_H
Administrator
Jeff_H's Avatar
Re: CAL 25 - Tweaked Boom, Chainplate Leak - Advice welcome
Originally Posted by kgs113 View Post
The casting on the front of the boom has spring loaded rod for the gooseneck attachment point. Never figured out why. Should be able to pull it out a little and rotate the boom.
These boats had what was referred to as roller reefing, in which the mainsail was reefed by wrapping the foot of the sail around the boom. As you note there was a rod which connected the casting on the boom to the slide on the mast. The parts were machined so that the boom could rotate when the boom is pulled aft from the mast and then would lock in place at that point of rotation when the spring pulled the boom back towards the slide. Typically the lock would engage at four points; 0, 90, 180, and 270 degrees of rotation.
Jeff_H is online now
