SailNet Community - View Single Post - Dynema to dacron splice?
post #7 of Old 04-04-2017 Thread Starter
svselkie02
Re: Dynema to dacron splice?
Then just bury the dyneema inside the cover, and do a standard taper splice such that you have ~10' of just cover hanging off the back.
Stumble, this sounds like the route to take but I'm not getting that last part. I'm picturing the bottom 20' of dyneema covered, including a core & cover tail of about 10' past the winch.
But then where is the 10' of empty cover coming from?
What keeps the strain on the dyneema and not on the cover where the winch grips it? If you connect the top of the cover to the dyneema with the tapered bury inside the dyneema, then doesn't the cover end up taking all the strain from that point down, as the dyneema just slips freely inside it? Or is the tapered bury at the bottom end, and if so, how to you anchor the top of the cover to the dyneema core so the winch doesn't slide it down? Or does the cover grip the dyneema adequately along its entire length?
Pardon my density here.
Thanks.
JV
svselkie02 is offline
