SailNet Community - View Single Post - Just purchased a 1973 Pearson 30, need advice.
post #4 of Old 05-14-2017
Skipper Jer
Skipper Jer's Avatar
Re: Just purchased a 1973 Pearson 30, need advice.
The plugs are out so there is no compression to over come. Can you rotate the pulley by hand? Maybe put a socket or wrench on it to help. Clicking could be a weak battery, a defective stater solenoid, a defective starter (dead spot on the commutator) or a seized engine. Put a volt meter on the battery. If that measures good (12 or more volts) while trying to start then measure at the starter motor. I'd make sure the electrical side of the engine was good before looking at the mechanical. Its between PB blaster and Marvel Mystery oil. PB if you got it. Is the deck depressed around the base of the mast?
Nor'sea 27
Don't re-accommodate me, Bro
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is online now
