SailNet Community - View Single Post - cs 36 merlin mast replacement
post #18 of Old 07-02-2017 Thread Starter
goboats
Re: cs 36 merlin mast replacement
There is also the possibility that the 385 single spreader mounts are within a close distance to my lower set and we just use mine and add the uppers ? . Will find out more Monday from Rig Right I hope.
Was thinking I could use all 3 spreader locations . CS at 20ft (lower factory position) then the pearson at a slightly shorter width and the cs on top with its factory setting . The middle spreader would not have much load on it and would kinda work as just as a cover for the bases . Bad idea ??
goboats is offline
