SailNet Community - View Single Post - A sad tale of a beached sailboat swallowed by the sea. Video.
post #10 of Old 11-24-2008
Bene505
Glad I found Sailnet
Bene505's Avatar
one word of warning—if you're running your engine when the boat in grounded, you run the very serious risk of running sand and other sediment through your cooling system and that can tear up the impeller pretty badly, so you'll probably want to inspect the impeller at your earliest convenience.
Add to that potentially putting more sand around your keel.
That said, I wasn't there.
Bene505 is offline
