SailNet Community - View Single Post - Snow Load Sinks Boats
post #28 of Old 12-27-2008 Thread Starter
Sequitur
... a logical conclusion
Sequitur's Avatar
Originally Posted by danielgoldberg View Post
The dink. Sequitur, you've got the dink on davits and filled with snow. Watch that. If you put too much load on that you could end up bending your davits. For instance, if the drain is not entirely clear, when that snow melts you will end up with a dink full of water, which is more dense than snow. Then it may freeze, and nothing good will come from that.
It doesn't look like your dink is covered, and it also appears you have her canted to her port side, which means the water won't drain even if you have the drain plug out.
Just flagging the issue. If you've got it under control, my apologies for meddling.
Daniel;
Thank you very much for your concern.
My dinghy, Non Sequitur is covered, and although the cover has sagged a bit, the dinghy's list to port is allowing melt water to run off. Also, when I hoist the dinghy, I always remove the plug and attach the end of the falls to its lanyard as a pre-launch reminder. I checked the drain when I was there the other day, and it was clear and dry.
Cheers,
Michael
1908 Wildschut Skūtsje
Sequitur is offline
