SailNet Community - View Single Post - FG layup schedule to achieve desired thickness
post #8 of Old 01-15-2009
sailingdog
Some epoxies don't blush or have a much reduced blush, like MAS epoxies...Or you can choose to lay up while the first layer is still tacky, before it cures fully.
The main reason most people go with Epoxy resins is because Epoxy resins have much better secondary (adhesive) bonding characteristics than do vinylester and polyester resins. Polyester and vinylester resins are much weaker when they can't form primary (chemical) bonds and have to rely on secondary (adhesive) bonding.
Two things to be aware of. First, epoxy resins deform and weaken at much lower temperatures than do vinylester and polyester resins, so you need to paint or gelcoat epoxy resin work in fairly light colors if the work is exterior. Second, epoxy resins are also subject to UV-degradation, so they need to be coated with something to protect them—paint or gelcoat.
Originally Posted by dgr View Post
Jason,
Thanks for that. So, what are the options to avoiding amine blush and insuring the highest bond strength between layers? Or can I go polyester or vinylester and just wax the last layup. It seems to me that everyone that does this type of work is using epoxy but I'm open to whatever will achieve the desired end result.
sailingdog is offline
