SailNet Community - View Single Post - Iron Ballast
Thread: Iron Ballast
post #2 of Old 10-11-2004
Sailmc
Iron Ballast
I have three years into a boat with an encapsulated cast iron keel. So far I''ve had no problems but I am in fresh water for only 6 monthes of the year. No problems yet. You might try a magnet to see if the keel is in fact iron. If you are talking about a cast iron keel covered in epoxy you can see any problems as the surface will start to blister and rust will start to pop out. If the integrity of the finish is fine you should have no problems and a bit of maintenence at the first hint goes a long way. It would not be my first choice but so far has been trouble free.
Sailmc is offline
