SailNet Community - View Single Post - At what point is enough enough?
post #15 of Old 05-17-2009
pdqaltair
pdqaltair's Avatar
SDs is right, that the first year is the worst.
Just remember, that boat maintenance, as a rule when done properly, gets lower rather than higher. If you do the preventative and proper maintenance, the big costs generally are avoidable. Bringing a boat up to spec, after a long period of questionable maintenance takes some doing, regardless of what boat it is.
I would highly recommend you read the Boat Inspection Trip Tips thread I started, as it will help you get a real baseline on what is needed with your current boat.
If you like the way the boat performs, sails and looks... there's no reason not to go ahead an invest in the boat, provided she's basically sound to begin with.
Looking at a boat from a purely financial perspective is ridiculous...since any financial perspective is going to say that not owning one is the only thing that makes sense. They are a financial strain any way you look at them, even if brand new.
You will discover flaws, dislikes and what has been neglected. Once you get it TRULY water tight and get through the to-do list, it will get better. Much better. But there is always a "list."
Just remember, every new "toy" you add requires maintenance. Simple is good.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
