I'm trying to figure out the best way to disconnect the Whisker pole from the jib and mast. I've done some reading, and haven't found this specific issue addressed. A friend who has more experience, suggested disconnecting the pole from the mast first. This seemed like a bad idea to me, as you then basically have a spear connected ot a lot of power you may not be able to control. But....did I listen to my logic? Oh, No! With him at the helm and me at the mast, I disconnected the pole at the mast. Well...this was weeks ago and my hand has healed now, but I was lucky! Yesterday, I tried to disconnect the pole from the jib first and found it difficult with tension on the sheet. Now, I'm thinking probably the best method is to jibe the main, in order to cover the jib and disconnect the pole without tension on it (this is how I furl the jib and it seems pretty obvious to me now. Fortunately I still have ten fingers ) Thoughts?
When you set the whisker pole make sure the jaws are facing up. That way gravity can help you when it's time to take it down. We always release from the mast first.
On my 55 ft boat the pole with the 1100 sq ft genoa would be a very dangerous object to release from the mast end. That is why it has a quick release mechanism at the mast end for the jaws at the jib end.
The quick release also lets you 'un-rig' rapidly if a man goes overboard; the jib flies free and can be used to heave-to or get back to windward and the properly rigged pole--- topping lift, down-haul and guy--- is stable and it is not necessary to de-rig until things become more stable.
You can (easily) release the mast end?? Would have thought you'd have a more or less permanently fixed butt end on a track going up the mast
On a boat small enough to end-for-end (sounds like what the OP is talking about) there really shouldn't be much pressure in the pole if you're deep enough to wing it out unless its really honking - maybe the OP doesn't have a trip line rigged running down the pole and had to actually disconnect it at the mast? I can see where that might cause some problems. Oh, and to the OP: always helpful if you're on the weather side of the pole, honking or not
With my large genoa (603 sq ft) we leave it furled and connect the pole to the sheets. Then we unfurl the genoa to the required size; ie in strong winds we may only unfurl half the genoa. Taking it down we furl the genoa first, then remove the pole.
ste has it right. Treat it like a spinnaker pole. Driving deep will help keep the load off, also ease the sheet a foot or 2. I don't think we're talking about a 55 footer.
First off all - "wing on wing" is a slow and unstable point of sail. Unless the wind is strong, you would better VMG on a deep reach. The pole is meant to hold the genny out of the main's shadow. With my 1300 sqft genny, trying to release the pole at the mast would be dangerous. When we gibe, I furl in the headsail, remove the pole from the sheet, raise the mast end to clear the staysail, then reverse the process on the oposite tack.
Given the way the question was phrased, I'm guessing the boat is 30' or less and does NOT have a mast track for the pole, nor any other type of fitting and has a plain ol' end for end pole with a couple rings on the mast. Think about it, if you could raise the mast end, why would you worried about which end to release first? The situation becomes fairly obvious at that point doesn't it?
The OP apparently has a 30' Yankee. If the boat is going hull speed DDW wing on wing, he will gain absolutely nothing by the "tacking downwind" tactic. He won't gain much, if any, speed, and will travel a longer distance. In a true displacement boat, once you have reached hull speed, or close to it, the fastest way to the next mark is the shortest way to the next mark. But as to the specific question: Yes, release it at the mast first.
If you have a Yankee 30 mkII, just for an example, your 150% genoa is 381 sq. ft., and a spinnaker is 778 sq. ft. Main and spin would have close to double the sail area of main and genoa.
Obviously, the sail area ( and complexity) is greater with a kite, but the principle is the same. Maximizing the sail area on a downwind reach. Am I missing something?
Related Threads
1.7M posts
173.9K members
Since 1990
