SailNet Community - View Single Post - Oil pressure light fades on/off
post #12 of Old 12-31-2009
hellosailor
A shop manual should also tell you how to test the switch itself. Often that's either an on-off connection or a variable resistance (most common) and you can test the sender with a multimeter. Senders do go bad, and if that happens you just throw it away and screw in a new one. A gauge is no panacea, it can malfunction too. And if the sender is bad--the gauge won't work either.
hellosailor is offline
