SailNet Community - View Single Post - Waterproofing/protecting wood
post #3 of Old 05-31-2010
PorFin
Seņor Member
PorFin's Avatar
Originally Posted by wind_magic View Post
Basic question ..
What do you usually use to waterproof wood ? I'm not talking about wood on deck that will be exposed to the elements all the time, or even anything external, I just mean oil or something you can put on a piece of wood so that it doesn't absorb water from spills when you are making dinner, that kind of wood protection. I just want the water to bead up and not stain the wood. I usually use tung oil in woodworking, but it is pretty pricey.
Thank you in advance!
Wind,
I'd personally stay away from any tung oil based treatment for any food prep area -- tung oil's pretty toxic.
Walnut oil is a good sealer, and can be rubbed in very well. You can buy it prepared/extracted, or you can simply get busy cracking walnuts and wrap the meat in a piece of cloth and extract the oil yourself. We used to use leftover Xmas holiday nuts to oil wood pieces.
Another alternative is to use a wax -- Johnson's will do the trick.
PorFin is offline
