SailNet Community - View Single Post - Bandsaw trick, Well we don't have a woodworking forum!
post #10 of Old 01-23-2011
Skipper Jer
Skipper Jer's Avatar
I did the tablesaw pre-resawing "trick" once. I wanted to resaw some cedar to line a chest. You want to be really careful doing this, if you do it at all. My cedar had some tension in it and what happened was "spectacular". The wood pinched the blade and caused so much heat the blade started to warp. A warped blade caused more friction and more heat and more warping. By the time I reached the off switch smoke was being produced. Removing the wood revealed my Forrest blade imitating a Lays potato chip. What is truly remarkable is once the blade cooled off, it was as flat as it was before this happened. Now I only resaw on my bandsaw using a wide resaw blade.
Skipper Jer is online now
