SailNet Community - View Single Post - AC Electrical Panel
post #6 of Old 02-28-2011
sailingdog
Originally Posted by 4arch View Post
The Paneltronics 9972305B is similar to the Blue Seas 8027 but is available a little cheaper and comes with 4 installed circuit breakers compared to the 8027's 3.
If money is not an object, Paneltronics and Bass Products will both customize panels in almost any configuration you want.
Bad idea. The AC panel needs to have a double breaker for the incoming power, so that you can break both the neutral and hot lines. If you don't have this and have a reverse polarity situation, you end up with live 110 AC wiring on the boat because the neutral line wasn't interrupted.
sailingdog is offline
