SailNet Community - View Single Post - Older Yanmar.. rebuild? replace? or?...
post #19 of Old 03-02-2011
LakeSuperiorGeezer
LakeSuperiorGeezer's Avatar
I still think a compression test with intake and exhaust valve adjustment is a good idea before pulling because then you will know what you have, most likely an engine that needs no work. If you decide to sell the engine, it makes a good selling point if the compression is within specification. I am assuming the maintenance was done as it should have been done when I state the engine is good to go as is.
LakeSuperiorGeezer is offline
