SailNet Community - View Single Post - Depth sounder with no thru-hull?
post #3 of Old 08-14-2006
sailingdog
I'd try and get a replacement transducer that will fit your thru-hull first. BTW, you do lose quite a bit of power on a through-the-hull setup, and it can be seriously affected by the hull material. If the hull is cored, it won't work. If there are any voids or bubbles in the laminate below the transducer, it won't work, etc...
sailingdog is offline
