SailNet Community - View Single Post - Rule Mate 2000 Bilge Pump sticking on?
post #4 of Old 10-17-2011
kd3pc
kd3pc's Avatar
for the most part the Rule is not the rule it used to be, cost is still a premium, but the pump quality is NOT. After having several fail as you did, I went to Johnson pumps with WaterWitch electronic switch and that has solved that. At least I am not replacing a pump every six months any longer.
The electronic switch takes a bit to install correctly, but so far no free run, no sticking on (or off) and with the Johnson pumps, I can keep a spare pump that fits multiple housings in a pinch..
kd3pc is online now
