SailNet Community - View Single Post - Beneteau First 367 for Coastal Cruising
post #5 of Old 12-11-2011
jackdale
jackdale's Avatar
I have used one for teaching coastal cruising. I quite liked it. It will sleep five in separate berths. In light air it moves well.
The galley is adequate. Nice chart table.
Downsides
There is no real double berths. The V berth is quite cramped for two, the aft double has one person sleeping under the the cockpit.
The large racing wheel combined with a cockpit traveller and the backstay adjuster make transom access virtually impossible. There is no gate so you have to climb on board at the shrouds. It has quite a bit of freeboard.
The head is a bit small and can be a little hard to access.
The top shelves in saloon are quirky. Stuff can fall off if you open the cupboard.
The holding tank is a bit small. The pump out is under the v-berth.
There is no cockpit table.
Will post more when it comes to mind.
jackdale is offline
