SailNet Community - View Single Post - Replacing Cleats
post #6 of Old 12-21-2011 Thread Starter
g0twind
g0twind's Avatar
Originally Posted by sailingfool View Post
Definitely use the alu backing plates, maybe 3/8" or so and 1/2 to 1 inch wider all sides than the base of the cleat.
It is negligent that the cleats lack backing plates.
Installing such will be only as hard as accessing the undersize of the cleats.
Follow the instructions in for potting the boltholes and bedding the cleats from here:
https://www.sailnet.com/forums/gear-m...utyl-tape.html
No advice as to increasing size or not, all being equal bigger is better than too small.
Cleat access is very good. Shouldn't be a problem.
Thank you for this very useful advice!
If I do go up in size, what do I do with the existing holes from the old cleats?
1974 Paceship PY23 "Barely Awake"
Hull # 001
g0twind is offline
