SailNet Community - View Single Post - what's involved in removing an injection pump on a yanmar 2gm?
post #5 of Old 01-22-2012
sawingknots
the lines are easiest to remove by using a wrench to hold and another to turn,if you arrange them fairly close together then use one hand to squeeze,i would strongly advise you to get a mechanic's manual for that engine,its been a long time since i worked on a 2gm but i'm fairly sure about the shims,it may require retiming
sawingknots is offline
