SailNet Community - View Single Post - replacement diaphram on bilge pump needed
post #3 of Old 02-06-2012
olson34
Question
While the pump might be a stock item from someone like Whale, there is also the chance that, like the knock-off winches that overseas builders used to make, they may have done the same with a pump.
Diaphram pump designs are kinda generic anyhow...
As long as the rest of the parts are in good order, perhaps you could source some reinforced rubber fabric and cut out a new diaphram, maybe.
olson34 is online now
