SailNet Community - View Single Post - Solar Panel demands
post #20 of Old 02-23-2012
casey1999
casey1999's Avatar
Originally Posted by jkzdad View Post
Thanks for the good ideas regarding the led lighting. Another big amp draw while cruising would be the nav system usage. I am Trying to plan for the days with the most energy draws. I think the need for some energy austerity on these big draw days is a big part of the answer. Thanks again
Bill
Wavelength
Does your boat currently have an amp meter on the panel (would show total amp boat draw)? If not, you should add one- gives a good indication of power use- check west marine for a selection. Once your panels are added, you can add an amp meter to the panels to indicate how much amps the panels are producing at any instant. This information will give a good indication of your energy balance.
casey1999 is offline
