SailNet Community - View Single Post - Full throttle needed to start Yanmar 2GM20F
post #21 of Old 12-20-2012
Faster
Re: Full throttle needed to start Yanmar 2GM20F
Originally Posted by 73Morgan View Post
Ran some tests, cranking and playing with the decompression lever with a cold engine does not feel like it changes anything, it only feels like the compression builds up after the engine warms up. This just might be explaining the hard start problem.
You should notice a distinct change in cranking speed between 'compression on' and 'compression off'... you'll also 'see' the engine shaking harder with the compression lever released as the starter tries to drive the engine through the compression phase.
If you're not noticing a difference, that's definitely something to look further into.
Faster is offline
