Carb Problem? - Page 2 - SailNet Community
 7Likes
post #11 of 45 Old 09-20-2014
Re: Carb Problem?
Originally Posted by newhaul View Post
Actually when an engine is running extremely rich it will exhaust blue smoke with a distinct gas smell just like the op described
Partially or un-burnt fuel will result in a black exhaust emission. Blue smoke = Oil and White = Coolant (steam). Of course the colors are subtle and I agree your nose is often a much better indicator when it comes to determining if your exhaust emissions are the result of fuel, oil, or coolant.
Certainly residue and the smell of gasoline in the engine compartment is cause for major concern. Had a customer with a very similar situation. Ended up he had connected the crankcase breather to the intake manifold which resulted in a high idle and blue exhaust emissions.
Marknid is offline
post #12 of 45 Old 09-20-2014
islander bahama 24
newhaul's Avatar
Re: Carb Problem?
I owned an auto repair shop for many years now I do marine to supliment my
VA and my cruising kitty What does it mean when a car is running to rich Running rich can be accompanied by a distinct exhaust smell, and in the extreme cases, some blue smoke
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #13 of 45 Old 09-20-2014
Tartan 27' owner
CalebD's Avatar
Re: Carb Problem?
I have taken the Zenith updraft carb apart several times for cleaning etc. It is quite easy to do - yourself. It is also quite easy to put the float pin in upside down - which will cause the symptoms the OP is experiencing - gas smell, dripping carb. Obviously I have done this.
A fuel tank with a lot of ethanol crud in it will also wreak havoc on the float needle, causing it to get stuck in the open or closed position.
There is an old expression: "If you want something done right you will have to do it yourself."
Everybody has one:
CalebD is offline
post #14 of 45 Old 09-20-2014
Re: Carb Problem?
"A fuel tank with a lot of ethanol crud in it will also wreak havoc"
Any crud will do.
But the most important point is probably that if you can SMELL gasoline, there's probably a fire danger.
1. Call insurance broker, make sure boat is overinsured.
2. Buy marshmallows and sticks.
3. Attempt to repair engine. Using bronze, brass, or beryllium-copper non-sparking tools.
Stick to the sequence and you'll be happy whatever the outcome is.(G)
hellosailor is offline
post #15 of 45 Old 09-20-2014
Re: Carb Problem?
How about:
1.Opening every hatch, port, or other opening you can
2. Turn off the gas at the tank
3. Sop up any gas that is visible
4. Disconnect from shore power
5. Go have a long lunch
6. Remove carb & take it home to clean in a well ventilated garage
As others have mentioned, if you can smell gas, heap big trouble.
Paul T
dabnis is offline
post #16 of 45 Old 09-22-2014 Thread Starter
Re: Carb Problem?
I went down again this weekend. The smell in the boat wasn't quite as bad, but when the bilge pump kicked on there was more residue on top of the water when it exited the boat. I know now that shutting the gas petcock should be done after each trip. I traced every line and every connection, looking for a leak. I am in agreement with you folks that there is a float problem. I did not start the engine. The carb had some wet residue on it, so I cleaned it up and also the area underneath it. I left a clean white paper towel. If that thing is stained next weekend, then that HAS to be it. Either way, I know I need to pull the carb.
ALSO, the mechanic failed to seat the choke cable bracket correctly. Not sure if this has anything to do with it, but I thought I would mention it.
Thanks again for your advice.
FirstCandC is offline
post #17 of 45 Old 09-22-2014
islander bahama 24
newhaul's Avatar
Re: Carb Problem?
He did that wrong makes me wonder what else he forgot to do.
My advise learn to do it the manuals are available and find a mechanic you can trust.
http://www.moyermarine.com/reference/a4manual2.pdf
newhaul is offline
post #18 of 45 Old 09-22-2014
Re: Carb Problem?
First, not all "professionals" are experts, or conscientious . I am not even close to being an expert on anything. Fortunately, my Dad started teaching me how to work on engines about 68 years ago. I don't know what your mechanical experience level is so forgive me if I am speaking out of turn.
I would imagine that Community Colleges, or something similar, offer small engine maintenance courses? That & a good shop manual or equivalent, can take you far. It is my opinion that the more work you can do yourself, with some limitations, the better off you are. Carburetors & distributors are generally fairly simple. However, a diesel high pressure injector pump is not. Older gas engines are relatively simple & easy to work on, in my opinion.
Paul T
dabnis is offline
post #19 of 45 Old 09-22-2014
Re: Carb Problem?
Newhaul-
"find a mechanic you can trust."
Reminds me of something Benjamin Franklin said, that any three men can keep a secret as long as two of them are dead. So any dead mechanic should be trustworthy, although, I'd still have reservations about some of them.
Paul-
I don't think you'd find engine courses in Community Colleges. In high school trade programs, yes. In "Trade Schools", yes. And some adult ed classes, like the New York State BOCES programs. But with a lot of the trade schools, the problem is that they are "student loan" mills, set up to take in anyone who is interested, get them signed up for government student loans, and then no one really pays a lot of attention to anything beyond getting those loan dollars. Sad to say, but a long-term racket. Asking a local car dealer's shop manager might get you a local referral, if there was one.
A good manual, and some you-tube videos, might be just as reliable a way to start.
post #20 of 45 Old 09-23-2014
Re: Carb Problem?
[quote]
Originally Posted by hellosailor View Post
Newhaul-
Paul-
Just a guess. I took night courses in welding at the local high school shop. If the OP does a search, he can probably find a course. If he has basic mechanical knowledge & basic tool skills & a good shop manual, he should be OK.
Interesting, I didn't know that
I forgot about you tube, right, I have seen some of those, like how to time a VW diesel, something I have done many times. Brought back some memories.
It is absolutely amazing what you can find on the internet.
Paul T
dabnis is offline
Help with Johnson 4hp carb AdamHowie Outboard 11 02-06-2014 01:58 PM
Outboard Carb question SantaAna12 Gear & Maintenance 2 10-11-2013 03:51 PM
How much gas in the carb? QuickMick Atomic 4 8 12-28-2010 10:24 AM
Cleaning/rebuilding a Honda 9.9 Carb SVlagniappe Gear & Maintenance 8 12-08-2010 07:37 PM
CRUSING THE CARB IN SUMMER jsgsail Cruising & Liveaboard Forum 4 05-24-2004 03:31 PM
