Carb Problem? - Page 5 - SailNet Community
 7Likes
post #41 of 45 Old 12-19-2014
christian.hess's Avatar
Re: Carb Problem?
Originally Posted by miatapaul View Post
Yes an electronic kits are great. I had an old MG with one on it, and it would start first crank every time, well every time the starter would crank! But if I was on a hill it always started as I rolled down it!
same here with my old honda cb750...I converted to dyna eletronic ignition...started in a nano second
however racers complained that they lost some power which was true on some bikes and ask any norton racer and they said the same points can be made to make more or less power provided you know what you are doing
anyways
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #42 of 45 Old 12-19-2014 Thread Starter
Re: Carb Problem?
This particular engine has FWC and electronic ignition.
The manifold doesn't look particularly difficult to remove, but I said the same thing about the thermostat housing!
Just remove the rear two bolts holding the exhaust, the carb, and two hoses, and then the manifold, right?
I was thinking the Dremel might do a good job of polishing up everything, no?
Edit: Oops, looks like I may have to drain the manifold first, some great stuff on this site:
http://www.weliveonaboat.com/2006/12...-atomic-4.html
If the site owner is also an SN member, then thanks for the pics on your site!
FirstCandC is offline
post #43 of 45 Old 12-19-2014
Re: Carb Problem?
IIRC the 3M "pads" were actually invented by Philips (Petroleum) in the very early 60's, and designed as road underlayment to ensure drainage.
But the modern ones from 3M are actually color coded, each color is a different hardness and 3M will gladly tell you which is which, for whatever trade you are buying them. Kitchen scrounge pads, green versus blue. Janitorial buffing machines & automotive products, usually red/white/blue. IIRC the white ones were the ones that were softest in that set.
In the US, orangewood "pusher" sticks for cuticle manicures are probably the softest "dowel" material. Never seen them in the hardware store though.
Pipecleaners and a bucket of Gumout.(G)
hellosailor is offline
post #44 of 45 Old 12-19-2014
RichH's Avatar
Re: Carb Problem?
MG! .... ignition system by Lucas - aka: The Prince of Darkness !!!!
christian.hess likes this.
RichH is offline
post #45 of 45 Old 12-19-2014
Re: Carb Problem?
thats the REAL DARK SIDE
Help with Johnson 4hp carb AdamHowie Outboard 11 02-06-2014 02:58 PM
Outboard Carb question SantaAna12 Gear & Maintenance 2 10-11-2013 04:51 PM
How much gas in the carb? QuickMick Atomic 4 8 12-28-2010 11:24 AM
Cleaning/rebuilding a Honda 9.9 Carb SVlagniappe Gear & Maintenance 8 12-08-2010 08:37 PM
CRUSING THE CARB IN SUMMER jsgsail Cruising & Liveaboard Forum 4 05-24-2004 04:31 PM
