FWC kit for Atomic 4, a good idea? - Page 2 - SailNet Community
 4Likes
post #11 of 21 Old 01-19-2015
JimsCAL's Avatar
Re: FWC kit for Atomic 4, a good idea?
I have a friend that did the conversion many years ago (he has since sold the boat). He did have to do an acid flush (using Rydlyme) of the cooling passages to remove any scale. The system worked well for many years. Pretty sure he used the Moyer system. I would do it if you intend to keep the boat.
JimsCAL is online now
The Following User Says Thank You to JimsCAL For This Useful Post:
hstege2 (01-19-2015)
post #12 of 21 Old 01-19-2015
travlin-easy's Avatar
Chuck, that's an old wives tale that never really had any substance to it at all. In reality, the only thing that remains inside the engine is the corrosion - not the salt. Now, the FWC system will provide you with lots of corrosion protection from that point forward. Be sure to use a good grade of antifreeze, check it frequently, and if the temperature is variable, the culprit is usually the thermostat.
My A4 has thousands upon thousands of hours on it, runs like a Swiss watch, and I would not even think of converting to diesel. If and when the engine dies, I would replace it with an A4 gasoline substitute, though they cost a bit more than a diesel replacement of the same HP.
Good luck,
Gary
travlin-easy is online now
The Following User Says Thank You to travlin-easy For This Useful Post:
post #13 of 21 Old 01-19-2015
Tundra Down
downeast450's Avatar
Originally Posted by hstege2 View Post
Hoping for some more good advice: My '79 A-4 runs well but the temp is quite variable. Reading about the Indigo FWC kit and their new t-stat sounds like cat's meow - but is it foolish to go at fixing things that are not real broken (yet). Last summer was my first with this boat/engine, so I don't have much history at all.
Thanks for your ideas.
When I re powered with an exchange from Moyer 5 years ago I included the fw cooling option from Indeglo. I am glad I have it. Installation took some "cleverness". I run a little cool here along the Maine coast. I added a rw pickup strainer that lives in the bilge. I can switch the rw pick up to it and fill the heat exchanger and wl muffler with antifreeze easily. It would allow the rw pump to serve as an engine driven aux. bilge pump if necessary. The engine is always "winterized".
Down
Islander-28, Marshall Sandpiper
downeast450 is offline
The Following User Says Thank You to downeast450 For This Useful Post:
post #14 of 21 Old 01-19-2015
h-
Aside from corrosion reduction, going to fresh water allows the engine to be run some 20-25F hotter, which improves power and economy. Salt water would have minerals crystalizing out, so raw water thermostats are normally a good 20F cooler to ensure against that.
Brewgyver likes this.
hellosailor is offline
The Following User Says Thank You to hellosailor For This Useful Post:
post #15 of 21 Old 01-19-2015 Thread Starter
Thanks for all the useful feedback, ideas, and experiences. Very helpful stuff!
hstege2 is offline
post #16 of 21 Old 01-20-2015
tommays's Avatar
The old wifes tail is called salt creep and while not much is said now in the past it was not recommended due to the scale chunks clogging the exchanger and it does due some wired stuff turning everything inside black
I due OWN two A4 blocks one always salt and the one 1970 block i rebuilt 5 years ago that was made FWC in 1980 by my PO
The saltwater block was carboned up like crazy due to the low water temp saltwater requires YET most things like head studs came off easy as i removed donor parts
On the other hand NONE of the studs were coming out of the block that had run FWC going back to 1980
Again due to lack of thermostat maintenance the motor was run way to cool and carbon forms under the valves in the air intake passages to the point of barley ABLE TO RUN
after much cleaning and gasket and seals
It has ticked away for 5 more while being run as long as 12 hours at a time when the LIS plays dead sea years and is celebrating its 45th Birthday
IMHP the indigo stuff is needlessly complex adding stuff that is just not necessary as it runs very happy with nothing more than the exchanger and second water-pump
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
The Following User Says Thank You to tommays For This Useful Post:
hstege2 (01-21-2015)
post #17 of 21 Old 01-21-2015
If you want to keep that A4 carbon free and keep those valves well seated, there's nothing on the planet better than Marvel Mystery Oil. Even Moyer highly recommends using this stuff, and in my old C-27, that engine would not start unless I kept the fuel and oil treated with Marvel Mystery Oil. This is the one product that I can truthfully say works very well in keeping those old A4s happy.
Good Luck,
Gary
post #18 of 21 Old 02-05-2015
I apologize for hijacking the thread, but do you run Marvel Mystery oil in your fuel and also some in with your oil?
FirstCandC is offline
post #19 of 21 Old 02-05-2015
islander bahama 24
newhaul's Avatar
That is what Gary seems to keep saying about the stuff. Won't hurt the fuel system. As much as he talks about it makes me wonder if he's the inventor ( he is old enough to be). . Seriously though marvel is good stuff
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #20 of 21 Old 02-05-2015
Yes, I usually put about a quart in the crankcase and 2 ounces for every 10 gallons of gasoline in the gas tank. There are instructions on the bottle for how much to add.
I am old enough to have invented this stuff, and sometimes wish I did.
Gary
FirstCandC (02-12-2015)
generator a good idea? Dave_E Cruising & Liveaboard Forum 91 11-04-2014 10:30 AM
Seemed Like a Good Idea... Squidd Gear & Maintenance 11 04-09-2012 08:42 PM
Yanmar spares kit good idea? batkins61 Diesel 9 04-07-2011 10:47 AM
Who thought this was a good idea? flyingwelshman General Discussion (sailing related) 14 04-08-2010 08:19 AM
Atomic Four Enigne Bad Idea? saurav16 Boat Review and Purchase Forum 34 05-22-2007 01:01 PM
