Transmission and throttle levers both move at the same time - SailNet Community
post #1 of 5 Old 06-11-2015 Thread Starter
I have a question about the pedestal mounted dual controls for the Atomic 4 on my boat. When I shift into forwards or reverse, the throttle moves along with the transmission lever, unless I hold it still. That makes for some interesting moments, especially when docking. I've owned the boat since late 2013, and I think it's gradually getting worse. Is there an adjustment I can make to avoid this?
Thanks!
Sent from my LG-D852 using Tapatalk
apneab is offline
post #2 of 5 Old 06-11-2015
fryewe's Avatar
Re: Transmission and throttle levers both move at the same time
Had this issue a few years ago. Was caused by dirt buildup and corrosion on the shaft. Had to disassemble the controls. Used vinegar to dissolve the corrosion (aluminum oxide) to make disassembly easier. Installed a cable brake on the throttle cable and adjusted it and haven't had a problem since.
Be careful. There are some plastic bushings in the mechanism that are likely brittle due to age.
Good luck.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is online now
post #3 of 5 Old 06-11-2015 Thread Starter
Thanks. Was the throttle brake already installed but needed adjustment, or did you install one?
apneab is offline
post #4 of 5 Old 06-14-2015
jhwelch's Avatar
I had this problem several years ago. There is a screw on the aft side of the pedestal which pulls in a clamp that holds the shift and throttle cables. If that clamp is slipping then both cables will move together and act very erratically. Because the threads my screw went into were stripped I had the boatyard use a holesaw on the pedestal to get at that area, fix the threads and also add a 2nd screw into that clamp "just in case."
jhwelch is offline
post #5 of 5 Old 06-14-2015
fryewe's Avatar
This is the brake...available widely at chandleries or on line...
The bolt head compresses the throttle cable sheath to apply pressure to the cable inside...the amount of pressure dependent on the adjustment of the machine bolt. The nut locks the bolt at the desired position. Use a wrench on the bolt head when tightening the nut to avoid changing the brake pressure.
Time to learn from mistakes so sailing can move on NewsReader News Feeds 0 12-21-2012 02:20 AM
Brevard man must move boats or face jail time - WFTV Orlando NewsReader News Feeds 0 02-04-2012 01:50 AM
Time to move up, but what boat? NCountry Boat Review and Purchase Forum 45 03-16-2010 04:15 PM
It's Time for me to move aboard Melrna Boat Review and Purchase Forum 31 12-09-2007 05:28 PM
Time to move on jbarros General Discussion (sailing related) 3 08-27-2003 10:11 AM
