Atomic 4 - head off, leave studs or remove/clean/install? - SailNet Community
 4Likes
  • 1 Post By fstarocka
  • 1 Post By hellosailor
post #1 of 8 Old 11-03-2017 Thread Starter
Re: Atomic 4 - head off, leave studs or remove/clean/install?
gr8 rich thanks will do that - yes I have a one way check valve I use to test outdrives with. Ill hook it up 2moro and see -
fyi heres a vid of it starting up: (i added a few degrees of advance and a 1/4 turn in and shes actually a tad peppoer than the vid - either way shes well tuned!)
I think the manifold is old - will keep an eye out for a replacement.. its holding up for now though!
RichH likes this.
fstarocka is offline
post #2 of 8 Old 11-04-2017
Tartan 27' owner
CalebD's Avatar
Nicely done.
Have you posted about this at the Moyer Forum?
Everybody has one:
CalebD is offline
post #3 of 8 Old 11-04-2017 Thread Starter
Originally Posted by CalebD View Post
Nicely done.
I did - got a bunch of stinky replies (none which pertained to my question). I just started ignoring them.. In my opinion a bunch of old timers who belong to an elite class of "I bought the manual for $55" - and if you havent/dont, we dont really help you.
Quite ridiculous - hence why I came here (and cruiserforums). Much more helpful folks around here -
fyi I left them as suggested by some old time engine guys who really know their stuff on cruiserforums.. plus I kind of agreed - as one chap said, "let sleeping dogs lie". At least I permatexed under the bolt heads "in case" steam tried getting thru..
post #4 of 8 Old 11-04-2017
Tartan 27' owner
CalebD's Avatar
Sorry to hear you had a less then stellar experience there. Seems to me you did pretty good work and nicely documented too.
When I replaced my engine gaskets I did not use Permatex on the studs and I did/do sometimes get some steam through one bolt. Good call.
Everybody has one:
CalebD is offline
post #5 of 8 Old 11-06-2017
f-
Don't forget that stuck parts often respond to judicious heat from a torch. Or, from a dry ice/alcohol slurry. (Freezing works as well as torching.) And then there's PBlaster (sold retila) and Kroil (only available by mail/online) both of which are incredibly different from WD40.
Even with a stud remover, using those other things gives you a head start. LocTite and such break down and release with high heat, too.
RegisteredUser likes this.
hellosailor is offline
post #6 of 8 Old 11-06-2017
Heat and cold:
Have done that before with bearings...oven and freezer.
Just takes a tad...tolerances so tight.
RegisteredUser is online now
post #7 of 8 Old 11-06-2017 Thread Starter
hi guys, I left them as is and just used a little permatex aviation under the head bolts - I used kroil over 3 days..then tried with a 1/2" impact wrench and stud remover - it was not budging so i just left them all..
Motor is running smooth as butter!
post #8 of 8 Old 11-06-2017
travlin-easy's Avatar
I love A4 success stories! I've owned two boats with A4s and loved both of them.
All the best,
Gary
travlin-easy is online now
Best way to remove and clean heat exchanger Perkins 4.236 edwmama Gear & Maintenance 10 10-29-2011 03:40 PM
Fuel tank clean/replace Cal 29 Atomic 4 banty2 Cal 5 08-18-2010 10:18 PM
remove fuel pump/atomic 4 jed Gear & Maintenance 2 03-28-2009 08:54 PM
This will certainly leave you shaking your head in disbelief... administrator General Discussion (sailing related) 10 09-20-2006 08:58 PM
Atomic 4 Studs TerenceONeill Gear & Maintenance 2 04-06-2003 11:12 AM
