Atomic 4 Alternator replacement - Page 2 - SailNet Community
post #11 of 16 Old 01-09-2015
oldlaxer1's Avatar
Re: Atomic 4 Alternator replacement
Originally Posted by travlineasy View Post
I have a 100-amp alternator on my A4, had it rebuilt in Carney, MD for $95 last winter, works like a champ. And, it doesn't load down the engine, even when the entire bank of house batteries are low.
Gary
Do you happen to recall who rebuilt the alternator? I'm in Towson. Thanks
oldlaxer1 is offline
post #12 of 16 Old 01-09-2015
travlin-easy's Avatar
B&W Auto Electric -Parkville 410 665-8998.
Gary
travlin-easy is offline
post #13 of 16 Old 07-23-2016
Mac Racer
We just determined the (original) alternator on our (vintage 1967) Cal 30 is shot. Spoke to MMI, who recommended their 55 amp alternator but said mounting arrangement for it differs from the old one and that mounting the new one might be "involved". Went to alternator shop and was told Delco #8903 (61 amp) would be a good replacement for the old one, with a similar mounting arrangement (which makes it attractive); however, it has only one wire (no field wire, as with the old one) and the change in wiring makes me nervous because of that (I am not an expert). Does anyone have experience with: a) mounting the new MMI alternator to an old engine, or b) using the Delco to replace an old alternator?
Zube is offline
post #14 of 16 Old 07-23-2016
Mac Racer
(I apologize if this is a duplicate post,.. am just learning the ropes on posting)
Zube is offline
post #15 of 16 Old 07-23-2016
Some of the older alternators had an exciter wire, which provided the higher amperage when charging. You should be able to find an online wiring diagram for the replacement, if not check Moyer Marine's site and you will probably find the answer to your questions.
Gary
post #16 of 16 Old 07-23-2016
JimsCAL's Avatar
And make sure whatever you get is ignition protected. Very important with a gas inboard engine.
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
Valeo Replacement Alternator jonjonza Electrical Systems 1 07-15-2012 12:12 PM
Universal Atomic 3 Diesel alternator fly2greenroom Diesel 24 08-31-2010 11:58 AM
Externally Regulated Alternator for Atomic 4 fixxxer0 Atomic 4 23 06-16-2010 05:45 AM
Atomic 4 replacement brak Boat Review and Purchase Forum 14 01-07-2007 04:53 PM
Atomic 4 replacement mr.fixit Gear & Maintenance 4 06-16-2005 05:48 PM
