Niagara 26 - cored or solid hull? - SailNet Community
post #1 of 6 Old 03-10-2016 Thread Starter
Was the Niagara 26 built with a cored or solid hull?
GeorgeHC is offline
post #2 of 6 Old 03-10-2016
Bristol 45.5 - AiniA
Re: Niagara 26 - cored or solid hull?
Don't know, but you can tell if you look at the interior of the full. You can see where the cored and non-cored parts of the hull meet, for example near thru-hulls.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #3 of 6 Old 03-10-2016
Dirt Free
boatpoker's Avatar
I've only surveyed one 26'. The topsides from the waterline up were balsa cored. Bottom was solid glass.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #4 of 6 Old 03-10-2016
Tanski's Avatar
https://groups.yahoo.com/neo/groups/...wnerspage/info
Try here.
Tanski is offline
post #5 of 6 Old 03-15-2016 Thread Starter
Thanks all. The boat was quite neglected, so I decided not to pursue it.
GeorgeHC is offline
post #6 of 6 Old 03-16-2016
Really well built and well designed boats. For Hinterhoeller it was a full-on cruising version of his Shark 24. Just a lot roomier.
We sailed one a lot - racing and cruising - for a decade.
Fast and comfortable. Matter of fact our former boat is for sale now in PDX.
Easy to single hand, as well.
The hulls are all solid layup and the hull-to-deck joint is a thru-bolted overlap. No leaks. The lead keel is bolted onto a substantial reinforcement in the molded in sump. The transom mounted rudder is semi balanced and the boat drives to weather with a feather touch.
If the wind dies it will motor all day @ 6 kts with a ten hp Yamaha OB. Burns 1/2 gallon / hour.
Loren
olson34 is online now
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
olson34
Cored or Solid Hull Chas H Mirage 3 10-02-2013 10:20 PM
cored vs solid fiberglass hulls MarkMiner General Discussion (sailing related) 32 02-21-2013 01:03 AM
Cored hull rayatwork Pacific Seacraft 3 07-13-2011 04:50 PM
Niagara 31 cored hull? Emmett71 Boat Review and Purchase Forum 21 02-09-2011 01:41 PM
Endeavor Hulls:Solid or Cored ? JakeLevi Boat Review and Purchase Forum 16 11-16-2006 06:11 PM
