Replacement fuel tanks - SailNet Community
post #1 of 9 Old 03-16-2016 Thread Starter
Hello all! I just recently bought a 34' Columbia and I'm going to repower with a 4108 Perkins and I need some info on finding a new fuel tank for the vessel. Please advise. Thank you!
Jbrd35 is offline
post #2 of 9 Old 03-16-2016
Matt's Avatar
Re: Replacement fuel tanks
what kind of tank where you thinking? Aluminum, Plastic, Fibreglass? why do you need to replace the fuel tank?
Matt is offline
post #3 of 9 Old 03-16-2016
Old enough to know better
My guess is it used to have an A4 or Palmer gas motor. I think I would just measure what you have and check the catalogs and get the closest size. Unless you have some need for something different like need for more capacity. Also the tank you have may be able to be used, though depending on location it may well be a good time to remove it while you have the engine out. Here is a list to start with:
Permanent Fuel Tanks | West Marine
I think plastic would be the easiest thing to use. I would look for at least 20 gallons.
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
The Following User Says Thank You to miatapaul For This Useful Post:
Jbrd35 (03-20-2016)
post #4 of 9 Old 03-16-2016
Just to give you some reference...local fab shop charges around $8/gal for a well built 1/8 aluminum tank, with baffle/s, not including wema sender.
L x W x H / 231 = gal IIRC properly...
captjcook is offline
The Following User Says Thank You to captjcook For This Useful Post:
Jbrd35 (03-20-2016)
post #5 of 9 Old 03-17-2016 Thread Starter
Yea it had a Palmer 60 which I removed. Someone had already removed the original fuel cell and was running off a day tank in the lazarette. I have a Perkins 4108 in my shop that's perfect for it. I plan on taking it to the Bahamas to live aboard and would like to carry as much fuel as possible since fuel is so expensive down there. I was hoping someone knew of an aftermarket brand that would drop in so I don't have to make one.
Jbrd35 is offline
post #6 of 9 Old 03-17-2016
JimsCAL's Avatar
Moeller makes lots of fuel tanks. Most marine vendors (like Defender) will be glad to custom order one for you.
Permanent Fuel Tanks | Moeller Marine
JimsCAL is offline
The Following User Says Thank You to JimsCAL For This Useful Post:
Jbrd35 (03-20-2016)
post #7 of 9 Old 03-17-2016
denverd0n's Avatar
Correct when L, W, and H are expressed in inches.
denverd0n is online now
The Following User Says Thank You to denverd0n For This Useful Post:
Jbrd35 (03-20-2016)
post #8 of 9 Old 03-17-2016
Broad Reachin'
kwaltersmi's Avatar
I replaced a leaking diesel tank on my Catalina 34 last summer and had one made from Ezell Industries. I supplied a few dimensions and they had it manufactured and shipped to me in less than 2 weeks for about $485. I ended up using Ezell because they are (or were at one time) the OEM supplier for Catalina's fuel tanks.
Catalina 34
kwaltersmi is offline
The Following User Says Thank You to kwaltersmi For This Useful Post:
Jbrd35 (03-17-2016)
post #9 of 9 Old 03-18-2016
OceanLink is a Rhode Island based company specializing in tankage. I've bought several tanks from them. Great customer service and support.
Skywalker
SkywalkerII is offline
The Following User Says Thank You to SkywalkerII For This Useful Post:
Jbrd35 (03-19-2016)
Cleaning fuel tanks Freedom007 Gear & Maintenance 10 10-28-2012 07:02 PM
Propane Replacement Tanks - $$$$$$$ cruisingmom Gear & Maintenance 27 01-30-2010 01:45 PM
Fuel Tanks brainstormers Gear & Maintenance 14 03-17-2005 08:42 PM
Fuel Tanks Nereus32 Gear & Maintenance 1 12-02-2002 01:30 AM
Replacement Tanks blondbabs1 Gear & Maintenance 0 09-14-2001 05:22 PM
