Hull deflection/oil canning - SailNet Community
 1Likes
post #1 of 13 Old 04-08-2016 Thread Starter
A 1985 S2 9.2A has been on the hard for 5 years. There is some moisture infiltration around some deck fittings but surprisingly little. My concern is about the deflection around the jackstands. One (aft port) seems to be pushed in almost an inch. Can the seriousness of this be evaluated before spending $700.00 on a survey? Thanks.
director98 is offline
post #2 of 13 Old 04-08-2016
Re: Hull deflection/oil canning
Have you looked inside the hull to see if the deflection has caused any structural components to crack or separate?
Often these will just pop back out, but you can't really know for sure. Check for indirect damage inside.
Jeanneau 54DS
Minnewaska is offline
post #3 of 13 Old 04-08-2016
HANUMAN
RobGallagher's Avatar
Yes, it might just pop back out. I would be sure it does before I purchased it. It the stand is not at a bulkhead, see if you can have the yard move it (or move it yourself with permission and knowhow).
WINDHOVER
1999 CATALINA 36 MKII
NOANK, CT
RobGallagher is online now
post #4 of 13 Old 04-08-2016
Dirt Free
boatpoker's Avatar
Five years ! .... pop out is unlikely.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is offline
post #5 of 13 Old 04-09-2016 Thread Starter
Thanks - I'll get my head and a light down there somehow.
post #6 of 13 Old 04-09-2016
You don't need to get your head in just your phone to record video of area.
ctl411 is offline
post #7 of 13 Old 04-12-2016
roverhi's Avatar
As long as the depressions haven't busted the interior woodwork/bulkheads loose it isn't a structural problem. It's doubtful that it will pop back out, however. May not effect sailing qualities at all. Fix is a slurry of epoxy and micro balloons, random chopped fibers, and/or glass cloth to fair out the depression. Not that hard to do yourself if you don't mind grinding and doing lay up over your head.
roverhi is online now
post #8 of 13 Old 04-12-2016
Not a deal breaker...when not shored properly this happened frequently...good place to beat down price a bit though. If it does not spring back completely it can be jacked out and stiffened from inside, geometry as in an angle shaped stiffener positioned to drain will work best. Epoxy albeit "stronger and having a more tenacious bond" creates hard spots. Secondary bonds using polyester are the same exact strength as hull, needs to be dewaxed and scuffed up just the same.
captjcook is offline
post #9 of 13 Old 04-12-2016
Senior Moment Member
SloopJonB's Avatar
Those kind of depressions are commonplace, generally due to poor blocking jobs. They seldom just "pop out" but they almost always will return to the normal shape in a week or two.
I wouldn't worry about it - worst case some epoxy filler is pretty cheap.
P.S. Captjcook is incorrect about poly secondary bonds being the same exact strength as the hull. Primary bonds are chemical as well as mechanical. Secondary bonds do not have the same chemical link as primaries - that's one of the big reasons for using epoxy for repair work.
SloopJonB is online now
The Following User Says Thank You to SloopJonB For This Useful Post:
director98 (04-19-2016)
post #10 of 13 Old 04-12-2016
Please check with your insurance company about using OEM materials for repair...pro's will not use epoxy to repair poly.
Tags
deal breaker , used boat purchase
Canning Your Food tomperanteau Provisioning 89 07-24-2015 06:56 PM
Oil canning hull of older Catalina Capri 22 kcjonz Catalina 2 07-07-2013 08:16 PM
Hull Deflection davidpm Gear & Maintenance 7 04-04-2010 10:06 PM
hull deflection OCD Boat Review and Purchase Forum 3 12-02-2005 06:41 AM
Mast Deflection Sue & Larry Gear and Maintenance Articles 0 05-24-2002 08:00 PM
